Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
    Oct 2005
    Does anyone know how to convert .m4a or mpeg4 files to a usable file for premiere pro 1.5
    i get a error message when i try to import these files
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi elessaroflegion,
    Your best format for Premiere Pro is WAV.
    How you get to this from .m4a or MPEG4 - that'll either be research on your part, or someone posting.
    Search the forums, or check out the "Convert" link, to the left <---
    P.S. You might want to edit the subject so that "permeir" reads as "premiere" - it'll help others when searching on "premiere"... Do that by editing your first post, and you can change the subject from there.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
    Dec 2004
    Australia
    As long as it isn't DRM'ed then it is basically just an mp4 file and there are numerous apps that can decode it to wav. faad, mplayer, dbpoweramp, foobar2k, etc.
    Oct 2005
    thanks everyone i am now learning the converting part because i know nothing about it
