    Jul 2004
    England
    Can i please get some help.
    Ok i have some CD's on my hardrive and they are all MP3 FORMAT SOUND.
    I am using Nero and all CD's copy but 1.
    Hardcore Nation - I renamed a few of the tracks earlier so it suited my ipod.
    However it wont add the tracks and i get an error.
    Cannot add file "desination of track .mp3"
    Reason: The file format is not supported.
    Yet when i use a different Copy or a CD thats the same format it adds it and gets ready to BURN.
    Whats the deal here? I very much doubt its corrupt and is definately that format... any ideas and how can i overcome this. I need this backed for me mam
    Jan 2005
    Try recoding as a mp3 file again....
    Jul 2004
    England
    How do i recode em as an MP3 file agen?
    Also it does it via WMP it converts then copies em
    Jan 2005
    I would try using a music converter, dBpowerAMP is a good one.
    Then remake a mp3 file from the problem mp3 file you have, I have had a similar trouble with an mp3 file and recoding or reconverting it again over the top of it work for me. Also try a fresh copy without renaming and see it works?....... Good luck...
    Jul 2004
    England
    Ok thnx alot guys, gr8 help as always
