  1. AGAINST IDLE SIT nwo's Avatar
    Jan 2004
    Stadium Of Light
    Hi,
    i am about to buy a tower Pc P3 800 128MB to run as a web server, i use
    Liteserve 2.7, but the tower only comes by it self, is there any way
    to work the tower from my laptop in a 2nd screen, it just it i am paying
    for hosting and now its costing to much, thanks.
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Take a look at TightVNC, but there's also others like GoToMyPC, or if running XP you can use Remote Desktop ....... plenty of options, depending on what OS your web-server is going to be running.
    If in doubt, Google it.
  3. AGAINST IDLE SIT nwo's Avatar
    Jan 2004
    Stadium Of Light
    well the tower comes with Win ME i could put XP on it, thanks for the reply!
