I want to delete certain subtitles in a subtitle stream that I consider unnecessary. How can I do this most easily?
I read different guides to demux and remux dvds. And of course some regarding the changing of subtitles. But the more I read the more I got confused.
Isn't there a simple way to just cut off some titles without creating a totally new subtitle stream?
No simple way/tool (yet), you must rip to text and then convert back to dvd subtitles images.
How could I do this most easily? Or which guide here would be most appropriate for this? As I said I'm quite confused at the moment (information overload, probably...
OK, but when I imported the subtitle stream in SubRip, can I just delete the titles I consider unnecessary and export the file, or do I have to be aware of anything else? And which format am I supposed to export to?
As far as I understood the following process, I have to use DVD-lab PRO (for instance) to remux the whole thing. But when I import the subtitle stream, the programm creates a totally new one. The content is correct but font, size, color, position and so on is different to the original stream. Is there a way to preserve the original format. Again, isn't it possible, since subtitle streams consist of different pictures, to just cut some of those pictures out and save it again? I would like to preserve as much of the original as possible.
A lot of questions, I know. Sorry for that and thanks for the help so far.
How to permanently delete subtitles in .mkv files?
By NeroLi8gerzid in forum SubtitleReplies: 1Last Post: 9th Sep 2011, 09:18 -
How to stream from 4 PC/360's to a single viewing source?
By CSavory in forum Video Streaming DownloadingReplies: 2Last Post: 10th Dec 2010, 16:16 -
delete subtitles with PGCedit?
By AlanHK in forum DVD RippingReplies: 5Last Post: 12th Jul 2010, 07:22 -
are subtitle displayed selectivily from a single subtitle track?
By rakan in forum Newbie / General discussionsReplies: 11Last Post: 21st Dec 2009, 18:21 -
subtitle workshop automatic delete lines with numbers only
By newnews in forum SubtitleReplies: 3Last Post: 20th Aug 2008, 11:53
