SPDIF In/Out Limitation using Realtek ALC850 chipset on a GA-K8NXP-SLI Gigabyte Motherboard:
It seems that the ALC850 implementation on the GA-K8NXP-SLI is LIMITED to two functions:
1. It can receive AC3 or digital audio via it's SPDIF_IN port and output that DIGITAL audio via the SPDIF_OUT port provided that you set your options to pass-through mode.
2. It can receive PCM (non-digital) audio signals via it's SPDIF_IN port and output that PCM audio signal out through it's analog speakers and subsequently record that signal. In this case no digital to analog conversion is necessary and pass-through mode should be disabled.
NOTE: IT CANNOT CONVERT DIGITAL SPDIF_IN SIGNAL TO ANALOG OUTPUT.
Subsequently, you cannot record the digital audio spdif_in signal.
Check to make sure your pass-through option is selected if you are only using your SPDIF_IN to SPDIF_OUT. Uncheck the "pass-through" option if you want the SPDIF_IN audio to go through your analog speakers or to record, just make sure that that audio signal is PCM and not digital.
I tried using NERO 7 and still had the same problem. Any suggestions?
Results 1 to 1 of 1
GA-K8NXP-SLI / GEFORCE 7800
Realtek HD has no Stereo Mix?
By EwanG in forum AudioReplies: 23Last Post: 4th Sep 2010, 09:53 -
No stereomix after installed Realtek drivers!
By LoveMyslf in forum ComputerReplies: 6Last Post: 6th May 2009, 16:18 -
Realtek audio card front headphone socket
By didikai in forum ComputerReplies: 8Last Post: 19th May 2008, 10:49 -
Configuring microphone w/ Realtek HD Audio
By Sean O'Scare in forum AudioReplies: 0Last Post: 24th Feb 2008, 08:05 -
Realtek Audio Problems!
By =CrAzYG33K= in forum AudioReplies: 3Last Post: 8th Jun 2007, 07:56
