Does Canopus Procoder encodes audio to AC3 or just MPEG2 and PCM? I am looking for the good ac3 encoder. if Canopus Procoder doen not encodes audio to AC3 canyou recomend one.
Procoder outputs wav or mp2 only, not ac3, so yeah, you'll need something to convert the audio after the fact.
As already mentioned, ffmpeg is one option, check the tools section for other ac3 software. Free programs can be excellent, if a bit involved to work.
For reasonably cheap and pretty good, I like tmpgenc's ac3 encoder, it works as a plug-in with tmpgenc stuff but can also run as a stand-alone, you just drop a wav file into the program, it runs, voila, ac3 file. It only does 2 channel, though, if that's an issue. I think it's $60-ish, check out tmpgenc website.
So does the TMPGEnc one, if you want to be precise.Originally Posted by laspis59
I've never had a problem with Besweet/FFMPEG, been using that method for 3 years now.Want my help? Ask here! (not via PM!)
Canopus Procoder: chapters in DVD-export? How?
By Lippy Lipstick in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2008, 06:09 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 04:07 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 01:10 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 22:25 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 22:25
