I've been using Mainconcept MPEG encoder to Capture / Convert my DV footage to MPEG on the fly. It's been working ok until a few nites back.
I then plop the resulting MPEG into Studio 8.12 and add a few transitions and titles and dump it to another MPEG for burning via DVD Editor (DVD MovieFactory)
Anyone have a good suggestion on:
1) a good transfer or capture tool that produces excellent MPEG quality output. (DV to MPEG or DV to AVI to MPEG)
2) and a good MPEG editor that allows you to add a few transitions and then outputs to MPEG. (Ideally it shouldn't have to encode the compliant MPEG's again... maybe just have to render the titles, transitions, etc.)
Thanks in advance
Results 1 to 1 of 1
Current HD standard is a FAIL
By simps in forum Newbie / General discussionsReplies: 78Last Post: 20th May 2009, 05:08 -
What's up with ffmpegx (current and 1.0.0)
By TryNiX in forum ffmpegX general discussionReplies: 5Last Post: 15th Apr 2009, 13:46 -
Current Situation re. +R and -R
By nlec in forum MediaReplies: 1Last Post: 23rd Sep 2008, 15:59 -
Connecting Bellexpressvu box to current cable setup
By samouellette in forum DVB / IPTVReplies: 1Last Post: 29th Nov 2007, 09:41 -
How much have you spent on your current video recording setup?
By Baldrick in forum PollsReplies: 21Last Post: 12th Oct 2007, 17:47
