Is anyone using this program?
I just started using it and it has been great...up until today.
I have noticed using either the Video Disc Creator or Mpeg File Converter that with some AVI files, the program does not read the size of the file correctly which restricts how much I can fit on a DVD.
Example:I will have an AVI file 173 MB, bout 23 minutes long and the Ultra DVD program will read the length fine(23 minutes), but show it is 4096 MB big!
I will have a TV episode, 42 minutes, 350 MB, and it will read it fine. Then add the next episode, same length, same size, and it will read it as 4096 MB!
Anyone familiar with this and a possible solution?
Thank you for any and all help.![]()
Results 1 to 1 of 1
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 17:57 -
flip video ultra hd to dvd
By catchum in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 06:04 -
Problems with Nero 8 Ultra and Dolby Digital output
By andy99 in forum Software PlayingReplies: 1Last Post: 31st Dec 2007, 12:18 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 07:16 -
powerdvd 7 ultra PROBLEMS
By swiss in forum DVD RippingReplies: 3Last Post: 19th Aug 2007, 16:24
