im using vobedit to demux a dvd..but watever m2v file i get i get an gop structure error when i import it to tda..did not happen to the last dvds i do it on..so i dont know...i fixed it by using tmpgenc and demux it again to m1v file but the quality was not as good as the original m2v file..any help?
Results 1 to 18 of 18
This might do the job: MPEG Sequence Maker.
Valid GOP lenghts (max.) are 15 for PAL and 18 for NTSC.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
can u have m2v files as input for MPEG Sequence Maker ? but i tried restream...how would u fix it in restream..im messing with restream rite now..seem like the new output retains all quality which is good news some wat
I'm pretty sure that MPEG-VCR has a GOP fixer.
Forum search on "fix GOP" reveals:
https://www.videohelp.com/forum/viewtopic.php?p=1037125#1037125
https://www.videohelp.com/forum/viewtopic.php?p=1123433#1123433
https://www.videohelp.com/forum/viewtopic.php?t=247566
https://www.videohelp.com/forum/viewtopic.php?p=1148716#1148716If in doubt, Google it. -
Originally Posted by cudencuden
Try it out... You might also try changing the "m2v" to "mpg".There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
cant input m2v with MPEG Sequence Maker, and i want to retain the quality, have to have the m2v format as product so i can do some audio editing, thats y i don think mpeg-vcr would help either..and i tried mpeg-vcr and it ddint find any error..so im really want to fix it using restream cause it gives my wat i want..heres restream settings
i know.but i would save that for last resort cause then the quality wont be as good
been trying for the longest time..the quality does change..can u show me how to do it?
Are you using the exact same software for playback ?
And by "quality change" are you talking about a difference between your M2V file prior to muxing and the MPEG file after muxing ?
BTW, you could always author with IFOEdit - I don't believe it is so anal about DVD compliance, and it's not as if DVD compliance matters here, since you're just gonna convert to AVI anyway.If in doubt, Google it.
How to change the Menu without affecting the structure of the originalDVD
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 20th Dec 2011, 08:34 -
how to change the Menu without messing up the whole DVD structure?
By yozloy in forum Authoring (DVD)Replies: 1Last Post: 22nd Dec 2010, 10:12 -
Change the aspect ratio of an m2v MPEG2 file?
By theDruid in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2010, 22:16 -
How to join m2v, the easiest and fastest way?
By hanugro in forum EditingReplies: 10Last Post: 4th May 2009, 06:32 -
Change DVD link structure (i think)
By nOmArch in forum Authoring (DVD)Replies: 0Last Post: 4th Apr 2009, 10:09
