Hi!
I have a question about the ME function.
What is does the different choices (Diamond, Hexagon, Multi-Hexagon and Exhaustive) do, and when should you change that option? And does it change encoding time?
Thanks in advance!
http://homepage.mac.com/major4/options.html
mencoder H.264 options:
[ME function] Sets the comparison function used for fullpixel motion estimation (affects quality). Available values: Diamond search (fastest), Hexagon search (default), Uneven multi-hexagon, Exhaustive search (very slow).
In my small test, the function changes encoding time as 78%, 100%, 105%, 411%. I need to do a different clip (more motion) for quality testing: all four looked excellent.
Thanks for your reply.
I encoded a movie the other day from a dvd source. I didn't change anything from the h.264 preset exept the bitrate wich i set to 1300 as an experiment. The result was quite blocky if i watched it in fullscreen in the dark parts of the movie, maybe a slight change of the ME function can make my movie less blocky?
h.264 encoding
By anonymous_whatever in forum Newbie / General discussionsReplies: 4Last Post: 11th Feb 2012, 12:56 -
H.264 Encoding - Sound Synching
By mabus in forum Newbie / General discussionsReplies: 5Last Post: 19th Nov 2009, 11:36 -
Adobe Premiere H.264 Encoding
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 27th Aug 2009, 02:24 -
MP4 AVC/H.264 encoding
By Jacobus Serpenti in forum Video ConversionReplies: 17Last Post: 1st Jan 2009, 08:18 -
Encoding to H.264 from Sony Vegas 8
By BlaenkDenum in forum EditingReplies: 5Last Post: 16th Jul 2008, 01:41
