I've had this AVI wonder card (7xxx) version for a couple of years, and every time I try to capture video / Audio from VCR I drop the audio. I can hear TV audio, I can hear VCR audio just fine. I hooked the cables up as required in the manual, I chose AVI file as capture, but when I do any capture from VCR, no audio.... GRRRRRRRRRR. Thanks for the help, I am going to try capturing from the "TV" mode tonight to see if it retains the audio.![]()
How is the audio connected? Try piping the audio into your sound card's line-in.
That is what the ATI setup says to do. I get Audio, it is just very low... In order to hear on DVD player you must turn up full blast, which is not good practice. I am looking where I can adjust volume, since the "TV" audio is fine, as soon as I go to capture composite, the audio goes down.
You sound cards mixer (or Window's) should have a volume adjustment.... have you tried there?
Dropped Frames
By SudsMalone in forum Capturing and VCRReplies: 4Last Post: 21st Feb 2011, 06:31 -
MiniDV to DivX/XviD (w/ AutoGK): audio out of synch due to dropped frames??
By alexon in forum Video ConversionReplies: 6Last Post: 17th Dec 2009, 04:54 -
You Get dropped frames? That's for you
By themaster1 in forum Capturing and VCRReplies: 2Last Post: 6th Dec 2009, 23:21 -
Pioneer DV-410V, I dropped it
By rimbaud in forum DVD & Blu-ray RecordersReplies: 4Last Post: 24th Apr 2009, 09:36 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 14:57
