Results 1 to 12 of 12
  1. can that play on a dvd player that supports divx? and i want to use autogk but in the advanced options it says divx or xvid but not wat ver. of divx. and it says avi or divx. Divx can be a file itself?
    You are in breach of the forum rules and are being issued with a formal warning. PLEASE USE BETTER SUBJECTS!!!! "DivX6" and "Can you" doesn't say anything.
    / Moderator Baldrick
  2. Divx6 is the same as Divx5 as far as the video encoding is concerned. It evey uses the same fourcc code to identify the codec. So any player that supports Divx5 should be able to play Divx6.
  3. and i wanna use atuogk but how could i put menue options
  4. As far as I know, only Divx's Create software supports menus and chapters at this time.
    Good luck finding a set-top player that supports those features...
  5. well any if i convert a video to hi-def is it high def?
  6. Originally Posted by hardballer
    If you have a hi-def source. Many Divx/DVD players can't play hi-def files. The Philips DVP-642 for example.
  7. oh some dvds are like high def right?
  8. if i have a divx avi file and just wanna add a menu it doesnt take away quality?
    Dec 2004
    Australia
    No reason why it should if you just create the xml menu and remux with fuse. If you use something else then maybe it will want to re-encode.
    DVD's are 480i/p or 576i/p only. HiDef would be 720P or 1080i.
  10. do u no any programs to add a menu?
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Divx Converter can do menus, but AFAIK no settop dvd player supports them yet.
    If in doubt, Google it.
