Geez, you guys must be getting sick of all my dumb posts but here comes another one![]()
I've got some video files that I want to put onto DVD they are all around 370MB each why is it that when I use Nero to burn them to DVD I can only fit 2 on a 4.7GB DVD??
Is there anyway to fit more? I figured at least 4 would be able to fit on it!
Try a forum search on XDvd or look in the guides section.
I'm not sick of you ...... yet.Originally Posted by wendle
... but you can make sure that never happens by spending a lot of time doing forum searchs, browsing the forums, and checking out the Guides and Tools sections, as pretty much all questions you'll have will be answered there somewhere.
Lesson 1:Originally Posted by wendle
Do not, I repeat ...... DO NOT .... just add your files to Nero - it is re-encoding them to DVD standard, and IMHO it is quite, quite poor at encoding. Burning Yes, encoding No.
At least try a more reputable all-in-one like DivxToDVD if one-click tools are your thang .... or learn to do it the manual way - http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm . Plenty more help in the Guides section - https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=to+DVD&howto...or+List+Guides - and in the Tools section - https://www.videohelp.com/tools?s=35#35 and https://www.videohelp.com/tools?s=40#40 .If in doubt, Google it.
Freeware for compressing DVD files
By Ricky_E in forum DVD RippingReplies: 59Last Post: 3rd Aug 2010, 14:11 -
Compressing .vob or .ifo files using DVD Shrink
By hostofsorrow in forum Authoring (DVD)Replies: 4Last Post: 21st Jan 2010, 23:19 -
compressing avi files
By romanstopme in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2009, 21:36 -
Compressing ISO files for DVD?
By mr_goodbomb in forum Authoring (DVD)Replies: 2Last Post: 5th Jul 2008, 09:32 -
Compressing AVI Files to Burn to DVD?
By ryevick in forum Authoring (DVD)Replies: 17Last Post: 27th Nov 2007, 22:59
