Results 1 to 10 of 10
  1. I was wondering if it is possable to fit a dvd longer than 2 hrs on on a DVD-5 and keep full quality
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Yes, if you redefine "full quality"
    Or you could use a higher compression format like MPeg4 (dix,xvid,wmv,h.264,vc-1,...) but you would need a compatible player.
    http://www.kiva.org/about
  3. full quality meaning the quality of the orginal dvd(just the actual movie)
  4. Banned
    Feb 2005
    USA
    If just the movie is less than or equal to the DVD-5 then Yes, if not then No. Some form of compression would be required.
  5. Take out the subtitles, remove other languages, convert lpcm audio to ac3. probably... depending on what the bitrate was on the original.
    Darryl
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yes.
    If in doubt, Google it.
  7. Originally Posted by jimmalenko
    Yes.
    how?
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Yes.
    how?
    Easy.
    ...provided that the original DVD was already on a DVD-5 to start with, or by removing unwanted audio tracks, extra features etc etc, it it soemtime possible that what's left will fit on a DVD-5 as-is. Then there's the ugly "Q" word - there's every chance that even if everything doesn't fit, DVDShrink or any other transcoder can normally do a quite respectable job in pulling it down to size, often with no noticeable difference in visual quality.
  9. ohh that is extrememly help ful..,l how do u do this
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Easy.
    Ya gotta read the fine print
    DVDShrink in reauthor mode and possibly http://members.dodo.com.au/~jimmalenko/DVDShrink32.htm or a number of other guides in the guide ssection should help.
    But I guess you've already looked there, right ?
