I think im gonna cry!![]()
After all of this https://www.videohelp.com/forum/viewtopic.php?t=283421
I now get an error when loading an AVI saying:
Could not open the video part of the file [file location, name etc].avi Only the audio part can be opened
Anybody tell me why and how i can fix it, before i neatly place a hand grenade with no pin in my tower?
Option> Environmental Settings> VFAPI plug-in> Directshow Multimedia File Reader; <----- right click on this and choose higher priority. Do this several times until it's at the top of the list. (Priority +1 or +2). Then try opening your avi again.
EDIT: I just read your thread. You sure you got all your codecs installed again? -
Not sure bout the codecs is there anyway i can find out what codecs i have/need?
You require the Xvid codec as gspot is telling you. You should have that one and Divx. And if in the future you get another avi file you can't play, use gspot again to figure out which new codec you need to install.
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
TMPGEnc 3 error 0.80070005
By impmon2 in forum Video ConversionReplies: 6Last Post: 18th Jul 2008, 21:00 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
