Hello,
I cannot transcode a DV file to PSP format using the ffmpegX GUI and PSP preset.
the error is
Encoding started on Wed Nov 2 17:32:08 CET 2005
Input #0, dv, from '/tmp/test.dif':
Duration: 00:01:36.3, start: 0.000000, bitrate: 28800 kb/s
Stream #0.0: Video: dvvideo, 720x576, 25.00 fps, 25000 kb/s
Stream #0.1: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Output #0, mp4, to '/tmp/M4V01933.MP4':
Stream #0.0: Video: xvid, 320x240, 29.97 fps, q=3-9, 300 kb/s
Stream #0.1: Audio: aac, 24000 Hz, stereo, 32 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[xvid @ 0x381324]XviD: Color spaces other than 420p not supported
any help would be very much appreciated!
thanks,
-frank
When there is this colorspace problem, try encoding first to "ffmpeg DivX" with "Decode with Quicktime" enabled then go back to PSP.
returning to the scene: need to transcode xvid/divx for psp
By cmwill84 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 03:10 -
ffmpegX 0.0.9x transcode stuck on 99%
By mattr in forum ffmpegX general discussionReplies: 0Last Post: 24th Sep 2008, 04:17 -
ffmpegX 0.0.9 - no sound in the output of a transcode
By mattr in forum ffmpegX general discussionReplies: 2Last Post: 21st Sep 2008, 02:56 -
ffmpegX and PSP h.264
By str in forum ffmpegX general discussionReplies: 4Last Post: 25th Feb 2008, 08:08 -
Conversion to FLV - ffmpegx doesnt work
By indianiec in forum Video ConversionReplies: 3Last Post: 17th Jan 2008, 00:36
