  1. Member MI6's Avatar
    Aug 2004
    MACEDONIA
    I have problem changing video speed in time line on selected part of video, it changes speed (slower or faster) on whole video not on selected part.
    I've try with Velocity but it is not what I want.
    Any sugestions???
    QUALITY HAS A NAME
    Apr 2004
    Miskatonic U
    Either use velocity envelopes and play around with the positions of the points to make the transitions suit, or split the clips on either end of the scene you want to change, and just change the clip in between.
    Read my blog here.
  3. Member slacker's Avatar
    Jan 2004
    SF, CA, USA
    I agree with guns1inger. SPLIT IT and work with it as a standalone clip.
  4. Member MI6's Avatar
    Aug 2004
    MACEDONIA
    O.K. Thanks for advice but I still can't fix the problem. I put some video clip on time line, then with "S" key on the keyboard I split part of clip (about 40sec) , and finally I change speed rate to slower or faster, but when I check the video it changes speed to whole video clip not on selected one. Maybe somewhereI go wrong in selecting the video clip???
    Regards.
    QUALITY HAS A NAME
  5. Hold down the CTRL key while stretching or compressing (shortining) the video clip to change the speed of the clip. You can alter the audio this way also.
