  1. I bought a nice SVHS on ebay that doesn't record but according to the seller plays great. I took a chance because it was cheap.
    I'm not interested in recording since I will be using it to playback tapes for capturing. But not knowing the inner workings of the heads, should I expect problems in playback now or in the future?
  2. Preservationist davideck's Avatar
    Feb 2003
    USA
    What model of machine?
    No recording at all? No audio?
    The heads are probably fine; they are shared by the record and playback electronics.
    If playback is fine, then chances are that something is wrong with the record electronics.
  3. Its a Toshiba W808, one of the "ProDrum "V" Technology" units.
    I asked what exactly happened when you tried to record, but it was being sold through another retailer not from the previous owner, so they didn't know. I haven't gotten it yet.
    I'm hoping you're right, that its something wrong with the electronics.
    Feb 2004
    Australia
    Provided it plays , and you can also , via the connection you using , able to see tv channels , then there shouldnt be a problem .
    The recording issue is mostly caused by the chip that controls that part of the function , has ceased operation , this dosent mean that the unit will pack it in soon , it could last years yet .
    However , the fact remains , that the ebay seller made a deliberate attempt not too disclose this particular problem up front , and if you dont ask before buying things in ebay , you do take a greater chance of being ripped off .
    As for repairing , if you want too , it's not worth it considering the prices they can be bought for at retail outlets ... here a new 4 head lg unit sells for $98.00au ... cheap
  5. I should have made it clear that the seller DID disclose that the record function did not work.
