  1. Quick question
    I use to mess around with ripping dvd's and what not a while back but got out of that game some time ago
    About a year or two ago I tried to cut different scenes from all my favorite movies and then put them on 1 DVD.
    The audio never matched up and I dumped the project
    is there software out there now that has made it easier and make the audio match up????
    thanks in advance
    USA
    Editing MPEG-2 is not easy. You have to do your cuts on a keyframe. Sync lose can be a problem. Some editors like MPEG-VCR work well, others also. Cuttermaran also works OK for a basic editor, but I dislike anything that uses the Net framework.
    But, look around a little. The programs have improved a little, but you still need to follow the 'rules' when working with any highly compressed format, MPEG-2 included.
  3. MPEG-VCR is the best software I've ever used for cutting MPEG-2 or VOB files and I've never had any sync problems.
  4. Originally Posted by btwell
    thanks in advance
    VideoRedo
    ~Luke~
  5. thanks for the heads up
    I was hoping the technology or area had advanced some in the last year or two, but doesn't seem that way
    laspis 59- I downloaded the trial version of videoredo and toyed around with it for a bit.
    I question for all of you though because I'm a little rusty. I'm assuming I still need to rip the DVD with dvd decrypter or something like that. I'm sure many of the dvd's have a lot more security now adays, is there a better program than others for ripping the dvd to vobs if I need to do that?
    in the past i also used dvd2avi, but I'm hoping that I wont have to do that because I would like to just rip and then go directly to cutting out the scenes that I want. Can any of you confirm...
    thanks in advance
    bt
  6. Mod Neophyte redwudz's Avatar
    USA
    DVDFab Decrypter will rip most all of the newer DVDs. Works differently than DVD Decrypter, though. Not as much control. I still use Decrypter for most rips and burning. The Sony ARccOS system needs Fab though.
    The technology hasn't changed because the DVD format hasn't changed.
