    Oct 2005
    I'm trying to transfer JPEG files from my PC to my DVD player,
    a Phillips DVP3050V/37
    My manual says my DVD player will play JPEG files that you record and finalize on a CD-RW Disc
    My CD-RW Disc is formatted in Windows XP using Roxio Drag-to-Disc
    After copying the JPEG files from my hard drive to the CD,
    and inserting the CD into the DVD Player
    I get the following error:
    Disk error
    -Please eject the disk-
    Playback feature may not be available on this disc
    Philips Tech support has no idea what the problem is
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    That's your problem, your DVD player doesn't have Roxio installed.
    Make a simple data disk and don't use multisession.
    Oct 2005
    After searching the Internet for "Burning Software",
    I was able to burn my JPEG images on my hard drive to a CD-RW disc, by making a data CD, instead of formatting a UDF disc that I normally use for storing files
    The data CD was readable on my Philips DVD Player
