Ok, i download mainly bin/cue and xvid/divx/avi
I use vso divx2dvd if its an avi/xvid/divx/
However i want to covert my BIN/CUE files to 1 DVD disk
Am i right in this? I extract each one and make each file an MPG. or MPEG. Using ISO Buster.
Then use virtual dub and make them all one clip? Then add it to VSO DIVXTODVD and burn?
Is this the easiest way for a bin.cue file?
Also... can someone point me to a guide for converting in virtual dub or how to add 3 clips togeather?
THNX
The methods Baldrick mentioned are probably the best for you.
But for VirtualDub, put in your first AVI, then under 'Files' click 'Append Segment' and add the second file. You can add them all in this way, one after the other. But there is a risk of video/audio sync problems with this method. And VirtualDub may choke on MP3 VBR audio, or audio sample rates that are off by a decimal point.
If I wanted to add several AVI videos together for a DVD, I would usually encode them separately, then use my DVD authoring program to put them together and not do any joining. DivxToDVD does this for you automatically so it's a lot easier.
So i realised, i just went to copy a file there that was 2 disks.
I just want to know...
I have
DiskA then DiskB
I have a chapter every 5minutes, will these chapters continue on
I ask this because it had disk 1 and disk 2 and each had 11/12 chapters instead of 23 chapters.
Will they be as one chapter once i make this DVD. Its so i can watch it as one DVD because its been split into 2 disks.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
