Hi everyone, it's been quite a while since I posted on this site, since then I've bought a DVD burner and up until now it has worked perfectly.
I am using Nero 6 Ultra Edition, my DVD burner is a TSST-Corp (Samsung/Toshiba) TS-H552B, it can burn single-layer and dual-layer discs.
For my project I was using TDK 8X DVD-Rs that have never given me a problem. I already built the DVD structures (VIDEO_TS and AUDIO_TS) with appropriate VOB, BUP and IFO files. All that is perfect. But when I go to burn DVD-Video through Nero (express or Burning ROM), it goes to 3%, then hangs and eventually says "Session Fixation Error". I've looked up the issue on this forum, but nothing really addresses my issue.
I've heard that I should buy better media, other than TDK what would you recommend, considering that could be the problem?
If that isn't the problem, what the heck is going on?
My movie file is small, only 365MB.
On a side note, I created an ISO file through TMPGEnc DVD Author and attempted to burn it through there but that thing wouldnt even start burning.
I am going to try to burn the ISO through Nero, but my questions regarding session fixation still stand.
Thank you so much.
Below is the log of my error:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 7/13/2003 2:49:42 AM
Nero version: 6.0.0.0
Recorder: <TSSTcorp CD/DVDW TS-H552B>Version: TS04 - HA 2 TA 0 - 6.0.0.0
Adapter driver: <> HA 2
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <SAMSUNG DVD-ROM SD-616 >Version: bpt3 - HA 1 TA 0 - 6.0.0.0
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : IC35L090AVV207-0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SAMSUNG DVD-ROM SD-616 atapi Port 1 ID 0 DMA: On
CdRomPeripheral : _NEC NR-7800A atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 24117248 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 127MB (130124kB)
Free physical memory: 17MB (17676kB)
Memory in use : 86 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.11.2005
UDF/ISO compilation
1:43:03 PM #1 Phase 112 File dlgbrnst.cpp, Line 1818
DVD-Video files reallocation started
1:43:03 PM #2 Phase 114 File dlgbrnst.cpp, Line 1818
DVD-Video files reallocation completed (no file modified)
1:43:03 PM #3 Text 0 File Isodoc.cpp, Line 5451
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
1:43:03 PM #4 Phase 111 File dlgbrnst.cpp, Line 1818
DVD-Video files sorted
1:43:03 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
1:43:03 PM #6 Text 0 File Writer.cpp, Line 127
Writer TSSTcorp CD/DVDW TS-H552B running
1:43:03 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3814
First writeable address = 0 (0x00000000)
1:43:03 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3814
1:43:03 PM #9 Text 0 File Burncd.cpp, Line 3081
Turn on Disc-at-once, using DVD media
1:43:13 PM #10 Text 0 File DlgWaitCD.cpp, Line 224
Last possible write address on media: 2298495 (510:46.45)
Last address to be written: 188241 (41:49.66)
1:43:13 PM #11 Text 0 File DlgWaitCD.cpp, Line 229
Write in overburning mode: FALSE
1:43:13 PM #12 Text 0 File DlgWaitCD.cpp, Line 1688
Recorder: TSSTcorp CD/DVDW TS-H552B, Media type: DVD-R
Disc Manufacturer: TTG02 -
Disc Application Code: 64, Disc Physical Code: 193
1:43:13 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 757
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 188242 (188242) = #188242/41:49.67
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 188242 blocks [TSSTcorp CD/DVDW TS-H552B]
1:43:13 PM #14 Text 0 File Burncd.cpp, Line 3318
Recorder and media-info
Burning to TSSTcorp CD/DVDW TS-H552B on a DVD-R media
1:43:13 PM #15 Text 0 File Burncd.cpp, Line 3694
Can only write at 8x instead of 16x to current disc
1:43:13 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 910
Prepare recorder TSSTcorp CD/DVDW TS-H552B for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 385826816
1:43:13 PM #17 Phase 24 File dlgbrnst.cpp, Line 1818
Caching of files started
1:43:13 PM #18 Phase 25 File dlgbrnst.cpp, Line 1818
Caching of files completed
1:43:13 PM #19 Phase 36 File dlgbrnst.cpp, Line 1818
Burn process started at 8x (11,040 KB/s)
1:43:13 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2104
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
1:43:13 PM #21 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 1:41,167 (101167ms) -> OK
1:43:13 PM #22 Text 0 File DVDR.cpp, Line 1407
Recording mode: Sequential Recording Mode
1:43:13 PM #23 Text 0 File Mmc.cpp, Line 18119
Set BUFE: supported -> ON
1:43:13 PM #24 Text 0 File DVDR.cpp, Line 1522
Start write address at LBA 0
DVD high compatibility mode: Yes
1:43:13 PM #25 Text 0 File Cdrdrv.cpp, Line 7827
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
1:43:25 PM #26 Text 0 File Writer.cpp, Line 318
13:43:25.908 - TSSTcorp CD/DVDW TS-H552B : Queue again later (Intervall : 5msec)
1:43:43 PM #27 SCSI -1176 File Cdrdrv.cpp, Line 1361
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x04CD0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x72
Sense Qual: 0x01
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0x60 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x01
1:43:43 PM #28 CDR -1176 File Writer.cpp, Line 335
Session fixation error
1:43:43 PM #29 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
1:43:43 PM #30 Text 0 File ThreadedTransfer.cpp, Line 221
conversion idle, stopping reader
1:43:43 PM #31 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
1:43:43 PM #32 Text 0 File dlgbrnst.cpp, Line 1678
1:43:43 PM #33 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 8x (11,040 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.12a, size=20576 bytes, created 11/1/2005 12:11:06 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/4/2004 12:00:00 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
well i have tried Intervideo WinDVD Creator 2, which burns the DVD fine but then when I play it it hangs on a certain point in the movie.
I downloaded imgburn, gonna try it thanks for your help.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Best "Multi session" DVD Image ??
By Anurag in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2009, 01:22 -
Session fixation error - what is it?
By coody in forum DVD RippingReplies: 1Last Post: 17th Aug 2008, 13:48 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
