Got an avi file and after I encoded it with tmpgenc the audio and video don't match up. There is a half second difference in running time, but audio is out of sync about 2 seconds the whole way through (slow). GSpot says:
Video: Divx3 Low Motion (div3) 620kb/s 25 fps
Audio: MPEG-1 Layer 3 128kb/s (64/channel, stereo)CBR 48000Hz
Video runtime: 2:08:31.040
Audio runtime: 2:08:30:840
I have used Canapus and CCE to reencode video with same result and for audio i have demuxed with VDub Mod, and Goldwave in MP3, AC-3, MP2 and WAV (uncompressed) with the assistance of ffmpeg. I tried to use golden wave's "time warp" to stretch the audio but it makes it worse. Any help is appreciated. Thanks in advance.![]()
Hypercube Time Stretcher and SyncView are two programs that say they can fix sync problems fairly easy. Haven't tried either one, though.
VirtualDub also has an 'Audio Skew' correction, though it's mostly trial and error. It's under Audio>Interleaving. -
Thanks guys, I really appreciate it. I will get to work and keep you posted!
MPC-HC Transform Filter deinterlace question, searched form
By gOdiSOnyOuRsIDe in forum Software PlayingReplies: 3Last Post: 6th Mar 2012, 00:58 -
Travellers to be searched for porn
By zzyzzx in forum Off topicReplies: 0Last Post: 26th May 2010, 16:01 -
Help me find the right solution please.
By abeaty in forum Video ConversionReplies: 8Last Post: 7th May 2010, 23:12 -
mkv subtitle encoding problems (Yes i searched and tried out everything)
By -Tom- in forum Newbie / General discussionsReplies: 5Last Post: 1st Sep 2009, 18:16 -
I have searched everywhere for this thermal take part...........
By SIRCOOKS in forum ComputerReplies: 3Last Post: 22nd Feb 2009, 02:19
