hi,
I've been using the VLC for afew months, with no problems.
However recently on any video file I play on it, the sound is terrible.
It sounds distored and very loud.
I've tried other versions, the same for them all.
any ideas.
Thanks.
Results 1 to 9 of 9
I don't know about VLC, but some programs store their settings in places other than the 'Program Files'. Deleting the program and installing another version may not change those settings. Have you tried 'Reset All' in VLC?
It has pages of settings for audio, things like 'Goom effect', which I have no idea what it does.If you can't reset, adjust some of them. I suspect the problem is not in VLC, though. More likely something in Windows or other audio programs that have changed things around and the path VLC uses for audio is different now.
@mister_to_you
I know that this is of no help regarding VLC Media Player but have you tried Media Player Classic.I highly recommend it.
BTW you have most probably got a codec problem or if you have installed another media player also,it could be a conflict between the programs,as already mentioned by CBC.
Quick Edit:And I DO NOT recommend codec packs like K-Lite Codec pack ect...In my experience they screw everything up.Stear well clear of them.~Luke~ -
hi,
thanks for the replys, I have updated my nvidia graphic card recently, so maybe it's so thing to do with that.
As for the k-lite codec pack, does anyone know of an easy way to now if you have all the codecs needed and how up to date they are?
thanks -
don't use codec packs !!
you can find all the (free)codecs you need at this site or other sites like doom.org -
Installing the whole codec pack will often cause you problems, but individual codecs from them are sometimes OK. Better to just look in 'Tools' <<<<< here for codecs and install only the ones you need. -
problem solved!
I was missing a codec.
DivXAudioCompressor4.02
thanks for the posts
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 07:28 -
display size between windows media player and VLC player
By kool_k in forum Software PlayingReplies: 4Last Post: 6th Aug 2011, 15:18 -
VLC player - bad vertical resolution
By igorek in forum Software PlayingReplies: 4Last Post: 15th Sep 2010, 17:39 -
Strange issues with VLC Media Player, No sound and distorted picture
By xoADAMox in forum Newbie / General discussionsReplies: 3Last Post: 28th Feb 2009, 15:58 -
VLC Media Player
By Flying Doctor in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 09:38
