I have a dual layer 16x AOpen burner and when I burn at 12x the buffer goes crazy and it takes 40 minutes as opposed to what took 19 minutes with 2.4 speed. It is a new burner and I have it installed as the primary and am using Nero to burn. The buffer fluctuates a lot from 6 to 99 during the process and I dont know it that has anything to do with it.
Any suggestions?
My Benq does something similar. I have since figured out that it simply likes +R discs more than -R discs even though it is dual format. I've learned to live with it.
I am using +R but maybe I need to try -R. I changed the virtual memory and it helped but it is still really slow.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer DVD Burner Use
By Aristocles in forum Newbie / General discussionsReplies: 4Last Post: 15th Oct 2009, 01:11 -
Is TS-H552D a dual layer burner?
By revjeff in forum DVD & Blu-ray WritersReplies: 5Last Post: 30th Jun 2008, 20:17 -
DVD Burner for writing Dual Layer
By StealthKing in forum DVD & Blu-ray WritersReplies: 9Last Post: 1st Feb 2008, 21:25 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
