Hi there! I'm looking for the perfect solution to archive all my DVs, but have unfortunately found none until now. I've tried the Divx 6.0 codec, but it was too sluggish and did not produce excellent results even at high bitrates(around 8000-10000kbps). While editing Divx videos with Ulead Video Studio, my computer had even stopped responding. 3ivx too was not efficient in encoding high-quality videos.
So, I decided to try MPEG. While being able to encode at a satisfactory speed, the colour of the output video doesn't seem too right. Video editing software like Virtual Dub also fail to edit MPEG videos.
Having said all these, can anyone please enlighten on which codec to use, please? Thank you.
Your going to see quality loss no matter what you use, especially if it's really good source. Compression does that....
Try this thread, it gets pretty technical at the end but the first few posts are the important ones as far as your concerned.
https://www.videohelp.com/forum/viewtopic.php?t=283196
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
