Hi,
I was wondering if it was possible to convert an hr hdtv avi to XSVCD format using TMPGenc?
Here's a summary of the file.
Width: 960 pixels
Height: 528 pixels
Audio
Duration: 42: 34
Bit Rate: 448kbps
Audio Sample Size: 16 bit
Audio Format: AC-3 ACM Decompressor
Video
Frame Rate: 23 frames/second
Data Rate: 278kbps
Video Sample Size: 24 bit
Video Compression: XVID
Please help
I don't see why not. Try this guide to start with. http://members.dodo.com.au/~jimmalenko/AVI2DVD.htm
Originally Posted by Shadowmistress
https://www.videohelp.com/xvcd.htm
XSVCD stands for eXtendedSVCD. XSVCD has same features as SVCD but it is possible to use higher bitrates and higher resolution to get higher video quality. XSVCD is basicly everything that uses MPEG2 video, is not within the SVCD standard and burnt in "SVCD"-Mode.If in doubt, Google it. -
I can't believe I made that mistake.What was I thinking?
Shame on me for also being a recent vcd user to boot!
Sorry about that. Thanks Jim.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 28th Aug 2008, 23:33 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
