I need help with Audacity, I have downloaded all the Nyquist plugins and still have not been able to change pitch on a prerecorded MP3. If I changed the MP3 to wave would that let me change pitch on recording. Are there any guides on using Audacity, I have only found one, but it does not cover much. Thanks Foz
Foz the newbie
Try converting to wav, then highlight selection or song and go Effects/Change Pitch. I'm not sure how thorough the downloadable manual is, but join the mailing list & you can get plenty of answers to your questions.
What mattso said. If you haven't selected the audio file, (Edit>Select All) do that and the effects should all be available. Even with a tutorial, it takes a bit of playing with. If you mess it up, just go to 'Edit' and click 'Undo' and you can start over again.
EDIT: You should be able to work in MP3 format without converting to WAV. I don't do it that much, but as long as the effect menu is not grayed out, it seems to work. Just make sure you select the file. -
Thanks to both of you for your suggestions, I will get on the mailing list, also try your suggestions. Foz
Foz the newbie -
(Edit>Select All) This enabled me to see the greyed out things in the Effects tab and I was able to make the pitch change. Thanks a bunch. Foz
Foz the newbie -
Good deal! You might take a minute to thank the authors of the program. It's great to see freeware programs out there written by enthusiasts with little regard to financial reward. Encourage them if you can.
Version 1.2.4 out very soon, I believe! It just keeps getting better & better.
Does anyone know how to use Clipfix with Audacity?
By snafubaby in forum AudioReplies: 4Last Post: 29th Jan 2011, 06:37 -
Audacity help
By efiste2 in forum AudioReplies: 3Last Post: 5th Aug 2010, 13:59 -
need some help with audacity
By shashgo in forum AudioReplies: 7Last Post: 16th Jan 2009, 01:21 -
audacity and mp3's?
By tchambers in forum AudioReplies: 9Last Post: 6th Dec 2008, 20:21 -
Audacity question
By Jeikobu in forum MacReplies: 2Last Post: 23rd Aug 2007, 10:57
