k i make a few animated movies from games etc. i used to use xvid mpeg-4 codec however thats dinosaur stuff. i realise wmv provides better quality for same file size. i have a movie inputted into vegas 5.0 as avi (codec radius or somehting) but once editted in vegas will be rendering it as wmv.. my question is this...
what settings will give me the best file size to quality ratio (this movie is to be downloaded from the net). so i want file size minimal but quality not to be hindered all that much. any ideas.... ????
p.s. when rendering with wmv i normally use settings as "best" and then set to "90" for quality but i normally dont touch any other settings as im not sure what would change etc.
Not all will agree with that.Originally Posted by daza
As for best settings, try a few experiments and see what you think provides the best compromise between file size and quality. Only you can determine what quality is acceptable to you!
There are 10 kinds of people in this world. Those that understand binary... -
I dont agree.Originally Posted by bugster
XviD kicks WMV's ass.~Luke~ -
ive found xvid gives good quality, however file size is ridiculous. i can get wmv to the same quality as xvid but with half the file size. for those of you whom ,live and die by xvid what xvid settings do you use to get these great results? maybe my settings are why i look down on xvid
There's no good answer to that, too many variables. Resolution and your target audience are big factors. If they are on dial up I doubt they are going to want to want to download a video for an hour just to see a minute or two no matter what the quality is.... It's usually a good idea to provide two files if your making this for a webpage. One for broadband and one for dial-up.Originally Posted by daza
Create a custom template with your desired resolution and do some test encodes. Drop the data rate until it becomes unacceptable. A quick hint, drop the framerate as well, less frames allows for less bandwidth per second. 15fps is adequate for the web IMO, even 10 if your aiming for 56ker's.
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
Need a video splitter that can handle all wmv formats and VBR audio codecs
By godfist314 in forum EditingReplies: 2Last Post: 5th Jul 2008, 16:15 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 10:16
