Hi I want to put multiple videos in a dvd I used nero and it didn't work. I am just putting a mepg on dvds. So several of them that I can select like the ons in regular dvd. Scene selection.
Eric Chan
You're doing what now ?
Back up the truck a little .......
You're using nero to do what ? Burn as a Data DVD ? Letting Nero re-encode your MPEGs ?
Regular DVDs are authored and have menus, so you're using one of Nero's authoring tools ? NeroVision Express maybe ?If in doubt, Google it. -
oki. just put it this way... I need a program so I can put multiple videos on a dvd cd. Now I want it to play accordingly from first to last. At the same tme have it like scene selection section.
Also same method but for VCD -
See if your DVD player can play raw MPEG - https://www.videohelp.com/dvdplayers
If not, you'll need to make your videos DVD-compliant if they're not already - https://www.videohelp.com/dvd
Then you'll need to author them - guides and tools are in the relevant headings to the left. Your authoring software should allow you to make a basic scene selection menu, but also have a Play All button so that each clip plays one after the other. One other way to do this is to put all your clips in the one track.
As for VCD, similar thing - it's all about how you author it.If in doubt, Google it.
Multi-Audio Stream to Multi Device Happiness
By ebobster in forum Video ConversionReplies: 0Last Post: 15th Nov 2011, 01:18 -
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 14:21 -
FLV - Multi Joiner, Multi Splitter, Multi Advert Removal
By oz_surfer in forum Newbie / General discussionsReplies: 0Last Post: 11th May 2009, 22:16 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 02:01
