  1. Hi
    I'm having a serious problem with my pc. My computer started acting funny about 3 days ago, It takes to long to respond and freeezes quite a bit. At first, I thought it had to do something with some softwares I installed recently, but that didn't helped at all. I also did a memory, virus and spam test, NO RESULT AT ALL.
    My system Spec:
    Win XP sp 2
    Amd Athlon XP 2400+
    256 PC2100 X 2
    onboard Video and sound card
  2. Member Soopafresh's Avatar
    Jan 2004
    Your hard drive might be taking a dump. Back up your important data to CD or DVD before you even start troubleshooting.
  3. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    run a spyware program like ad-aware or spy bot search. test your hard drive out with a utility from the manufacturer. go to trendmicro website to use the free virus scanner.
  4. Banned
    Feb 2005
    USA
    When was the last time you defragged the hard drive?
  5. I fixed the problem, I had to defragged my second hard drive. Thanks for all ya'll help.
