Im trying to compile a VCD DVD with DVD Lab and I'm having a problem. I've done this many times before with no problm but this time I can't seem to get this right. After compiling this DVD I goto watch it before burning it, some of the chapter have scratchy audio and one chapter has no audio. The audio exists in the project and on the original files sounds fine what could be the problem?
I agree to use ffmpeggui for the conversion, although I haven't found DLP to give me any problems when I've used mp2s before.
What is your source from? Is it from a dvd rip? There may be hidden chapter info still in the headers and that's known to confuse DLP.
Or is your source from a fresh conversion? Does it have closed GOPs? Did you import elementary streams or a muxed mpg into DLP?
What are your audio and video biterates? If they are variable and both go too high at a particular point, it will choke on your player and the dvd emulating software will reflect that as well.
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
