I'm capturing TV shows off my VCR, it seems that the letter "S" as in Said, Some, etc. seems to peak and thus resulting in non-pefect audio, liveable, but not perfect.
I was wondering if anyone has figured a way to fix this.
Normalize then drop the volume down a bit???
Thanks,
Troy
Volume too high, you need to lower the input volume. (This is while you capture).
If it doesn't improve as you lower your input volume (line in, usually), then it may be your VCR has audio coming out of it way too "hot"... and unless your VCR has a volume control...
Once you've recorded distorted audio, really no good way to fix, when the audio is too loud, distorted, or "hot". You have to fix this before you capture.
<font size=-1>[ This Message was edited by: homerpez on 2001-12-23 21:59:47 ]</font>
Removing humming sound during talk
By AjnabiZ in forum AudioReplies: 14Last Post: 22nd Oct 2011, 19:14 -
Removing hard-coded sub from an MKV file.
By peterock in forum SubtitleReplies: 2Last Post: 27th Dec 2009, 21:42 -
silent recording or removing sound from video
By johnquest in forum Newbie / General discussionsReplies: 3Last Post: 6th Apr 2009, 01:13 -
Removing Scratchiness with Sound Forge 8?
By solarblast in forum AudioReplies: 12Last Post: 17th Nov 2008, 11:30 -
Does removing DTS sound in movies help Dolby?
By JohnnyBob in forum AudioReplies: 22Last Post: 11th Sep 2007, 16:53
