I think this is the same player as the Tevion QS-808. Does anyone know if it is possilble to play sub or srt files with divx files on this dvd player? Is there a firmware upgrade that might allow me to play divx files with the subtitles?
Thanks.
Come on someone out there must have some suggestion. I noticed that several people had bought the Tevion. Do you have any advice?
You could just burn the files to a cdrw and test it yourself.
I only have the DVP642, it will only use srt files and they must have the EXACT same name as the avi. Plus, to get them to work, I have to choose the subtitle file first in the file menu, press play, it reads the file into memory, and then choose the avi file and press play.
It may be similar with yours.Google is your Friend
MKV file not supported on Cello 3D TV
By sjpriest79 in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2011, 17:39 -
Any program that adds srt files to mkv files
By Peterrrrr in forum SubtitleReplies: 11Last Post: 30th Nov 2008, 03:21 -
2 xvid files 2 srt files
By blot in forum Video ConversionReplies: 4Last Post: 25th Sep 2007, 10:34 -
Putting 2 QT Files w/ 2 seperate .srt files onto a DVD
By whoracle in forum ffmpegX general discussionReplies: 5Last Post: 22nd Jul 2007, 02:57 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
