Hello everyone
I'm having a problem viewing some burned DVD's on my DVD player. It's a Pioneer DV-444, and the problem is that the image 'rolls' quickly up the screen - kind of like an old TV with a busted vertical hold. (It's tough to describe) So far it's happened with a burned image file that I downloaded, and a DivX file that I converted using Avi2DVD. Naturally I searched the forums (this one and Doom9) and I couldn't find a solution.
Any ideas?
Okay, seeing as you do not state where you are or in your profile i'm going to do some assuming here 8)
Is the video black & white ? If you are in NTSC land i'm guessing you have PAL video that you are burning to dvdr....
My old Pioneer DV-343's do that also as they won't convert PAL to NTSC.
You cna check the videos with AVIcodec to see what the FPS is.
I beleive you can check them in Windvd to see if they are pal or ntsc also but i dont recall as i usually know or check them with AVIcodec.
EDIT:
P.S.
I think this is more of a video problem than a dvd player problem 8)
Help!! Can you create a DVD for both DVD player and hold data files for PC?
By musicalsolutions in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2010, 06:32 -
New DVD to hold 2000 movies on 1 disc
By Rudyard in forum Latest Video NewsReplies: 41Last Post: 8th Nov 2009, 06:10 -
what size of the movie a dvd can hold?
By volam in forum Authoring (DVD)Replies: 13Last Post: 27th Mar 2008, 16:37 -
Looking for clear dvd cases that hold 4 discs multi fold
By chewie8008 in forum Off topicReplies: 13Last Post: 30th Nov 2007, 07:59 -
Vertical hold problem with Majix PhotoStory 5
By pdvdr in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2007, 11:10
