i just got this ulead video capture software but i am using a pinnacle av dv capture card,it works fine with it but am I not breakin the rules bY not using the pinnacle studio 4.1 that came with the pinnacle av dv capture card,i have a lot of problems using pinnacle to capture even after patch update especially audio video sync problems.Is my hardware safe using it with ulead software or aNy other capture software.Ulead works fine for me.
Use any program you like if it works for you. It won't hurt anything.
If you are having problems with a particular program, go to their company site and look for a forum on that program or a list of FAQs.
Or do a Google search for a independent forum. You will likely find someone with the same problem and someone else that has a cure or workaround.
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 13:27 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 10:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 05:58
