Hello,
I have quite a few MPG's (VCD format) that are split at 700MB since I used to burn them to CD prior to owning a DVD burner.
What I am wondering is if the community has some suggestions for software that will convert the movies and then burn to DVD.
FYI, I'd really prefer to support a smaller company if possible as I already know about Nero and Easy Media Creator.
RGDS & TIA
Curtis M.
PLEASE use the search,
http://www.google.com/search?domains=www.videohelp.com&sitesearch=www.videohelp.com&sa...&SUBMIT=Search
https://www.videohelp.com/tools?convert=VCD%20to%20DVD
and please try post in correct forum, this is no dvd to dvdr. moving you. -
Baldrick,
Sorry about posting in the incorrect forum.
I know about the tools listed here I would just liike input on what users prefer and why.
RGDS -
TMPGEnc DVD Author is good for putting VCDs onto a DVD. There is no need to convert a VCD MPEG 1 file to a DVD MPEG 2 File as the VCD spec is DVD compliant aswell. You would need to resample the audio to 48000 khz but, I'm pretty sure TMPGEnc does that for you. Just add the MPEG 1 VCD files, add a menu if ya want, then burn.
Capture Software Recommendations?
By Prince Valiant in forum Capturing and VCRReplies: 19Last Post: 17th Jun 2011, 23:59 -
Software recommendations
By ucime in forum Newbie / General discussionsReplies: 7Last Post: 20th Feb 2011, 00:47 -
Best video editing software - recommendations.
By dbanimal in forum EditingReplies: 10Last Post: 1st Dec 2009, 10:43 -
software recommendations
By deftones in forum EditingReplies: 3Last Post: 12th Nov 2009, 19:33 -
Looking for software recommendations for newbie
By emiko45 in forum Authoring (DVD)Replies: 3Last Post: 14th Sep 2007, 17:29
