right i want to rip my dvds to avi so can have them on one dvd.
first i installed AutoGK then run it and followed the guide on how to use it
step by step
then at 1pm i started it al was going well but after 13 hours it was only 51% done and by the site on a 2.8 ghz computer it should have taking 2-3 hours and 6-8 hours on a 1.ghz pc.
i have a amd 3000+64 756ddr.
so i need help cos it has gone wrong some where can some body help me out with this please tia
plus after 13 hours i stop AutoGK i check the avi it was 999 meg but when i tried to play it wmp would not play the file .this could be cos it is not a comlete file i think
cheers
its a dvd i bought from the shop
i used dvdcrypter to rip the vobs i done everything step by step from the guide this is my first try at ripping dvds i got the latest version from the web site yesterday
tia
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 16:14 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 02:17 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 18:42 -
Making 32-bit VFW-ACM codecs available to XP 64-bit Edition.
By gastorgrab in forum EditingReplies: 5Last Post: 19th Aug 2007, 12:12
