HI,
I'm working on our schools website, and have been given a couple of DVD that they would like to put on the website to stream of the website.
What's the best way to do this, converting over to I assume a avi or WMV file
WMV, it's the most universal format you can use and it has a very high compression (providing you select it when encoding). You can use something like Divx for AVI but most people are not going to have the divx codec installed so they'll either have to install it or not view it.
The only real other choice is mpeg1, that doesn't compress with the same quality as much as WMV though.
help converting WMV to AVI
By user943 in forum Video ConversionReplies: 5Last Post: 11th Nov 2008, 11:39 -
Converting .WMV to .AVI - What should I use to do this?
By Hank Kinsley in forum Video ConversionReplies: 3Last Post: 16th Oct 2008, 05:54 -
converting wmv to avi
By evile1690 in forum Video ConversionReplies: 1Last Post: 9th Jan 2008, 05:15 -
Help converting home movie dvd to avi/wmv for web
By dancingbear0420 in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2007, 14:35 -
Help converting .avi into .wmv
By Theros in forum Video ConversionReplies: 13Last Post: 5th May 2007, 19:10
