strange one I have two dvd burners . lg multi gsa 4163 b & MSI Dr16f
working in a NF7 board under xp service 2
They both wont run a dvd movie from direct load.
under nero 7 thay both will only burn at 8x or 4X will not show any other speeds on dvd .
what can i do to correct this .
both are running as master and slave on the cable
Have tried the restin property and even removed them and reinstalled
Try disconnecting one of the drives. My DVD burner is on its own IDE channel.
FWIW on the same PC, I have a Lite On DVD-Rom (master on ide channel with another CD-rom as a slave) that won't autoplay a DVD movie if any other application is open.Cole
Stand alone recorders; more of a problem than PC recorders?
By videobruce in forum DVD & Blu-ray RecordersReplies: 24Last Post: 13th Nov 2009, 11:27 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 15:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 15:59 -
Xvid and Divx playback problem on TV set
By herbapou in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Sep 2008, 12:17 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 01:29
