i'm trying to add a little eye candy to my menu. instead of just havning the item selected highlight i wanna add like a finger pointing at it. am currently using dvdlab pro to author. thxs in advance
How diffiuclt this is depends on how you want it to look. If you want a photgraph of a finger to apper beside the choice, you need to use a switched menu. The is a good tutorial on switched menus at the mediachance web site.
If you are happy for the finger to be flat colour, like the highlight, all you need to find an appropriate wing ding font with fingers in it, and use one as part of menu button (just make it invisible for the normal state).Read my blog here.
thxs will mess wit make items invisable in normal state.haven't gotten that crazy yet. been making generic menus
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 02:50 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 10:07 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
