I have some video that is on DV tape.
It's been recorded in long play.
I'm having trouble transferring the video onto my PC.
My application, Ulead Video Studio, starts off by complaining about the correct driver not being there.
But, then when I record, it does start recording.
BUT... then every few seconds the video footage and sound mangles up.
I can't figure out what the problem could be.
I can't see how I could be missing a driver.
Normal video is captured fine... no problems.
It seems as though the long play is causing the problems.
Thanks.
OM
Results 1 to 9 of 9
Does it work fo a SP tape or live capture?
I'm assuming IEEE-1394 transfer here.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
LP mode has many negative issues when played on other than the same machine that recorded it. Over time, the same camcorder may not play it.
hmmm... i wasn't aware of that.
ok... what would you suggest i do?
i was thinking of recording onto vhs.
and then transferring to the pc.
or maybe record straight to a dvd?
my end platform will be to display on a website in a relatively small screen, so quality won't be an issue.
thanks. -
i dont have the camcorder it was recorded on.
i can play it on another camcorder fine.
it's only when i go to capture that i get problems.
Trouble capturing video from site - please help
By dr12 in forum Newbie / General discussionsReplies: 9Last Post: 28th Sep 2010, 21:15 -
Converting long play to short play
By NiteCrala in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2010, 08:46 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 19:04 -
Video capturing help, having trouble please
By monigg in forum Capturing and VCRReplies: 9Last Post: 29th Apr 2008, 12:03 -
Trouble capturing video from my JVC GR-DA30 camcorder.
By Baby Mike in forum Capturing and VCRReplies: 1Last Post: 27th Dec 2007, 17:33
