I have an old analog capture card on my PC (miro dc20 by Pinnacle). I would like to be able to play these motion jpeg files on my mac and edit them as well. Usually you can just download a motion jpeg codec for the pc and it will play these old files. What is the solution for my mac so I can throw the old frozen TV dinner box they call a pc out the window?
More Info:
The format is "Motion JPEG OpenDML, 640 x 480, Millions Integer (little endian), Stereo, 44100 Hz, 16 bits
Movie FPS: 29.95
Playing FPS: (available when playing)
Data Size: 523.7 MB
Data Rate: 2.1 MB/sec
I found a workaround solution for my problem. It won't allow me to play my old files but if I just convert them on my PC to a .mov in DV format, the results are perfect. It sucks because I have about 500 music videos in the old format and they will all have to be converted. I'll just convert as I go I guess. I'm still curious if there is a codect though. My G5 will encode alot faster than my 450 mhz Dell
They don't play in QuickTime as they are now? I have plenty of motion jpeg video (already in mov containers) which plays in QT. It could be something to do with endian-ness though ...
no they won't play...says it doesn't have the proper compressor.
AVCHD (1080i) ve Motion JPEG (HD)
By pemongillo in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2011, 20:05 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
How to convert to AVI Motion JPEG?
By BobAchgill in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 16:59 -
Method for encoding Motion JPEG for PSP
By ByteMe72 in forum ffmpegX general discussionReplies: 6Last Post: 13th Nov 2007, 17:02 -
How do I convert Motion JPEG to MPEG-1?
By TheEvilHammer in forum Video ConversionReplies: 6Last Post: 18th Oct 2007, 18:58
