I have nanoPEG Editor which came with my video card. I use it to cut video commercials from my mpeg2 files. Is there another program that can cut parts from a mpeg2 file leaving the rest intact?
Results 1 to 10 of 10
This is a block of text that can be added to posts you make. There is a 255 character limit
Womble MPEG Video Wizard is a great tool if you want to do more than just cut out parts of video eg add transitions.No re-encoding just like VideoRedo so its very fast.Originally Posted by StealthKing
Thats if you can afford $120
Edited~Luke~ -
laspis59 wrote:
You need to get your facts right! Videoredo does not re-encode and is every bit as fast as MPEG Video Wizard and it also does quite a bit more for less money!Womble MPEG Video Wizard is a great tool if you want to do more than just cut out parts of video eg add transitions.No recoding like VideoRedo so its very fast.
Thats if you can afford $120bits -
Yes VideoRedo dont re-encode.I have it,its very fast!Therfore my facts are correct.
Maybe I should have put that MPEG Video Wizard doesn't re-encode just like VideoRedo,so its very fast.
Dont insult me.
Look at the VideoRedo comments section,I rated it highly.~Luke~ -
laspis59 wrote:
I apologize if my post insulted you. Your first post regarding videoredo is confusing and I thought you were saying that MPEG Video Wizard was fast and did not re-encode and that videoredo does re-encode.Dont insult me.bits -
Thats alright wwjd,sorry I took it the wrong way,I should have put my post across more clearly.Originally Posted by wwjd
~Luke~
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 19:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 16:39 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 09:45 -
[solved] Major MPEG2 Cutting issues. Looking for program that will work.
By ShadowBlink in forum EditingReplies: 17Last Post: 17th May 2007, 20:55
