I have a general question. What's considered a 'good' bitrate to convert? I don't have to worry about high defination or even large screens. I have normal tvs and I don't plan on buying a new one anytime soon. What I want to do is not waste space by highest quality that is useless. I know I don't need anything fancy, so why wastse several dvds in the process?
Also I was told that the GOP also affects the quality of a dvd but what is considered a good GOP? Picture only sounds like the best option but I was unsure with the information I found.
I'm currently using TMPGenc 'beta 12' according to my about file. I am currently converting using 4000 kbs bitrate and a picture only GOP. Video into mpeg-2 and sound mpeg-2. Most of the files I'm trying to convert are avi's but I'm not sure of the codecs.
If you know any good bands, recommend them to me. It doesn't matter what langage they sing in. In fact I prefer 'foreign' bands.
Yay for firefox, and the fun it brings -
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm
http://members.dodo.net.au/~jimmalenko/calc.htm
Some people use a bitrate that is sufficient enough to represent the information whilst at the same time almost completely filling the disc. Others swear by CQ mode, where the quality of the file is a set value but the filesize remains unpredictable. It really depends on the situation as to which way you go though, and without any firm examples, I can't really give any more specific advice than that I'm afraidIf in doubt, Google it. -
Originally Posted by anathemic_nerd
But like jimmalenko mentioned theres no hard and fast rule to it. Just experiment and see what you like. Use rewritable discs so you don't waste blanks as you test. Just give it a go and take notesDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
If you want to make sure your dvd player plays the movies correctly, I wouldn't mess with the GOP structure if I were you. You will get very unpredictable and undesirable playback behaviour if you don't know what you're doing and your player may not be able to play it at all.
Tmpgenc's default GOP setting is I:1 P:5 B:2 or IBBPBBPBBPBBPBBPBB which is within dvd spec. Some authoring software requests you use closed GOP's which eliminates frame interdependancy between GOPs and makes for better chapter accuracy. I would suggest you use this as well. That GOP looks like this: IBBPBBPBBPBBPBBP.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Converting Dvds, Settings with bitrate
By Ekeus in forum Video ConversionReplies: 24Last Post: 22nd Mar 2010, 18:19 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
What's the Best Bitrate for Converting DVDs to .264 MP4 files for xbox 360?
By keyed in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 02:04
