Hello,
I have two MPEG2 files that i had encoded using TMPGEnc, so their about two gigabytes each, i want to shrink each of the mpeg's so they fit on a 4.7 Gb dvd+r disc....
At the moment TMPGEnc cannot author the two mpeg's as they go over the exceeded limit by approx. 4500(mb i presume).
So which software should i use to shrink the media files?
And how easy is it to actually shrink the media files?
Thanks in advance for any replies.
So ...... how big is each file again ?
You really should be encoding them to the correct size in the first instance (hint: choose the right bitrate). If you insist on shrinking these current files, Rejig can transcode MPEG-2 directly, and I have written a guide in the Guides section that tells you all about it. Another alternative is to author oversize anyway, and then use a transcoder like DVDShrink, DVD2One, Shrinkto5, CloneDVD etc etc to pull it back down to size.If in doubt, Google it.
shrinking a dvd file to email it
By Haopengyou in forum Newbie / General discussionsReplies: 9Last Post: 13th Jul 2010, 09:41 -
Shrinking a video file size
By gilmer in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2009, 23:14 -
Shrinking MKV file
By Peleus in forum Video ConversionReplies: 5Last Post: 13th Nov 2008, 04:08 -
MPEG2 file plays in windows media player but not properly in premier cs3
By ibanezfreak in forum EditingReplies: 1Last Post: 20th Oct 2008, 03:42 -
shrinking 24 gb hd mpeg2 file to dvd9?
By nick101181 in forum DVB / IPTVReplies: 3Last Post: 18th May 2008, 20:30
