I am trying to transfer some VHS tapes to DVD. I just got a Pinnacle DC1000, so I dont have to wait for files to compile from DV. So I capture in Premiere 6 and import the files to DVD-lab were I author the DVD and compile it. Everything goes fine untill I play back the DVD and its jumping all over the place and out of sync. I checked the files outputted by the DC1000 and they look and sound great. Note, I am encoding a 9Mpbs CBR.
What media did you use ?
If could be that your player can't handle the bitrate, or that the media isn't good enough to serve that bitrate constantly to your player, or simply isn't good enough.
Before burning them to disk, play the files from your HDD using a good software player such as powerDVD (note: WMP is NOT a good software player for testing) to see how they behave.Read my blog here.
Uncompressed PCM would push the total bitrate above the spec maximum, but is should be OK playing back from HDD. What does the bitrate viewer in DLP say about the stream ?
Read my blog here.
I think, I just went over in total bitrate. I am going to convert the audio to 384 kb/s AC3, which I know has word for other people. What are some good AC3 incoders?Originally Posted by guns1inger
Or you could just take the video rate down to ~8Mb/sOriginally Posted by nirvhillRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yea, but that would mean I would have to rencode about 6 tapes.
I think it would just be easyer to find a Ac3 encoder, plus I would really like to get the best video quality.
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD Lab Pro compilation problem
By JohnCPun in forum Authoring (DVD)Replies: 11Last Post: 8th Jan 2008, 17:31 -
Problem with DVD LAb Pro...
By GangstaRap in forum Authoring (DVD)Replies: 19Last Post: 20th Dec 2007, 14:23 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 16:13
