HI, does anyone know if its possible to Capture Playstation 2 video (coming from s-video) using DVD Xpress with no delay?
When i mean no delay, is that when i use CapWiz (incl'd software), if i give it a PS2 signal, my contrls are 2 second later than the actual picture.
I've heard that Dscaler is recommended for playing games, but unforauntely when i try to use dscaler /w dvd xpress, it didnt work.
any other capture programs that work like dscaler can work with dvd xpress?
Actually, i'm also diaspointed with Capwiz, what's the best capture program for DVD XPress?
Thanks a bunch.
You need whats know as S-Video splitter or S-Video+Audio Splitter or could try cheap way S-Video Y-Cable
Rigth way Self Power model like this one
http://www.hometech.com/video/svsplit.html#CD-COV9202
Wrong way Y-Cable
http://www.pccables.com/70724.htm
There are some heavy duty high shielded one out there.
You maybe be able to get way with the cheap model VOPEX-SV-2-LC and be sure check out the VOPEX-SVA-4-LC to at http://www.vpi.us/ and http://www.hometech.com/ and http://www.smarthome.com/ -
SHS is suggesting that you split the S-Video output from one to two and plug one into the computer, for recording ... and the other into a TV so you can actually PLAY the game (with no latency).
This will work if all you want is to record some game play BUT if you truely desire to play with just the computer monitor then nope this will not solve the latency issue.
You could always try a cheap PCI type TV Tuner capture card ... such as the Avermedia DVD EZMaker PCI or one of the LeadTek Winfast PCI cards.
Audio to video delay value on a DVD
By nic2k4 in forum EditingReplies: 20Last Post: 7th Dec 2011, 03:06 -
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
Blackmagic Intensity Shuttle - Problem capturing from Playstation 3 PS3
By tuffjam in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2010, 21:08 -
Can you delay the start of the video on a DVD?
By rayden54 in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2010, 08:53 -
How to delay video?
By nick256 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2009, 23:51
