hi i downloaded DivX to DVD converter becaise i heard it was good for converting pal to ntsc. So i loaded all my DVD files from the Video_TS folder and then i change the settings to make it into a NTSC like the guide says http://forums.afterdawn.com/thread_view.cfm/220673 . But when i press convert nothing happens and it wont convert. whats the problem?
That thread is a bit confusing. Did anyone actually confirm that the program will convert from a ripped DVD?
If you have NeroVison Express try it. The PAL to NTSC conversions are quite easy.
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 13:55 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 09:06 -
Converting homemade PAL to NTSC
By Kernos in forum MacReplies: 12Last Post: 18th Jan 2008, 15:48 -
Argh! More converting PAL to NTSC!
By Nilfennasion in forum Newbie / General discussionsReplies: 5Last Post: 2nd Sep 2007, 19:56
