New DVDs has a new copy protection(Arccos) that old dvd decrypters does not support so try:
Try rip the DVD to the HD with latest DVDFab Decrypter (free).
or
Try install latest AnyDVD ($40)and you should be able to use DVD Shrink and DVD Decrypter or any other tool as usual. AnyDVD runs automatically in the background.
and
If you still can't shrink the DVD with DVDShrink try first with rip it to the HD with DVDFab Decrypter or AnyDVD and then use latest FixVTS or Vobblanker .
Closed Thread
Results 1 to 30 of 78
Just to add more info for the newbies:
Its down to copy protection,DVDFab Decrypter can bypass most of the latest protections,as can AnyDVD which is my tool of choice.
DVDShrink and DVDDecrypter cannot bypass the newest protections,you see,so therefore you cannot rip.~Luke~
I agree with laspis59. I also use anydvd. They update frequently. Shrink and DVD Decrypter are not being supported now, but you can use them for the features you want if you have anydvd running in the backround. I have read on these forums that DVDFab Decrypter has had some problems.
I know about Decrypter, but is Shrink also not being supported any more, How comes ?
What movies have the so called, 'latest protection' ? I haven't had problems yet. Even ripped 'Sith' with Shrink, so when should I start worrying ? So Shrink has also secomed to the 'dark side' ?
Sony's protections are the ones you may not be able to rip.Originally Posted by cyflyer
BTW the author of DVDShrink abandoned the project and now works for Nero,on Nero Recode.
~Luke~
Look at ReJig. It is a simple tool and can only duplicate the main movie. Interface is a little simple as well. However, that said, it has duplicated DVDs that the others have failed to. It has saved me several times. Its a nice tool.
I tried DVDFab Decrypter to back up my Bewitched DVD and it fails. What did I do wrong? Is there a specific setting I have to do? I don't want to buy AnyDVD because I only buy about 4 Sony titles each year.
"Half empty or half full, it's still only half a glass" - What Dave Says
Quite a few people have had issues with that DVD-Video. The following URLs may be helpful:Originally Posted by sapiendut
<http://club.cdfreaks.com/showthread.php?t=153419>
<http://forum.doom9.org/showthread.php?t=101887&highlight=bewitched>
and especially this URL:
<http://forum.digital-digest.com/showthread.php?t=56592>.
i tried to make a copy of my "The Longest Yard" with AnyDVD turned on with DVD Decrypter and with DVD shrink and it didnt work, so i tried DVDFab Decrypter and it stalled at the same point. Is there something im doing wrong here?
i tried anydvd with dvd shrink already and it wouldn't open the disc...it got to a point in the video and stopped, giving me a "failed to read disc" error....
DVDFab Decrypter was updated for "Lords Of Dogtown" & worked perfectly on "Bewitched" for me, without ever even having Anydvd on my system.Originally Posted by VirtualDoobMon
And "The Longest Yard" is from awhile ago so doubt it has anything to do with needing DVDFab Decrypter to be updated
that is what i figured...i jsut downloaded DVDFab today so i must have the latest version
I was getting the same error when backing up Bewitched with AnyDVD & shrink in Full Disc mode as well. Try reauthor mode and backup only the main movie.
I have been using DVD Decrypter for quite some time now the latest version is 3.5.4.0 Unforntuatly there will be no more updates for it. And there are now 2 codes that is does crack. The same is true for DVD Shrink (newest version 3.2.0.15) the IFCC took it over. It may be updated in the future I do not know for certain but you can find it here http://www.dvdshrink.org/what.html So I recebtly switched to DVDFab Decrypter but it does not work for the most recent code that is on the Bewitched and Madagasgcar DVD. The features for Shrink were the best I have seen. I am guessing that a DVDFab Decrypter update is my best bet but I will look at other programs in the meantime possibly AnyDVD.Originally Posted by sapiendut
DOES ANYONE HAVE ANY SUGESSTIONS ON FULL DVD BACK UP? OR OTHER GOOD PROGRAMS TO RUN?
go get the update for DVDFab decrypter that just came out today; it does have the fixins for Madagasgcar and probably Bewitched also
kip
DVDFab Decrypter was updated way back for Lords of Dogtown, which also works on bewitched, and was just updated again today to work on the newest protection on madagascar, you need to update programs on a regular basis to keep up with the new protections 8)Originally Posted by Sector 7 G
I had no problems backing up STEALTH. I used DVDFAB DECRYPTER to rip then DVDRB-PRO and burned it with DECRYPTER.
I have a mate who does NOT have the latest Fabs & Decrypters etc & was not aware of the problems with the new copy protections etc.
He is a Shrink fan from way back.
But for those who know Shrink inside & out, the following may make sense to you.
He managed to back up Madagascar a few weeks ago after much heartache on the last known DVD Shrink, by setting a start point up from the beginning & then dragging the slider back to the beginning. He said he got the whole lot?
I have not played with shrink like that, but it COULD be a work around.
Maybe I'm talking out my arse too??
In hindsight it is much easier to just download the latest apps.
PS region 4 & PAL
I found I cannot rip "Santa Jr." with DVD Decrypter or DVDFAB DECRYPTER. Any suggestions? How do I know for sure it is not simply a bad DVD? It plays ok in my setup DVD player.
Added Dec 10 2005:
Never mind. I went out and bought a second copy of the DVD and that one worked fine. I just wish there was a way to know for sure if the problem is an encryption problem or if it is a bad DVD problem.Zakkkkkman
willx24601 wrote:
hmm... did anyone try this? it worked for me.... i just wanted to give my method... biggrin.gif
1- using DVD Decrypter Version 3.5.4.0 ripped ISO DVD on your pc (iso) if you're having problems, just change the option on DVD Decrypter - CSS tab - from I/O Key Exchange -> Brute Force TO Brute Force -> I/O Key Exchange or to the other option Brute Force.
2- Drag the ISO file to DVD Shrink 3.2.0.15 the black window where it would load up, and take out the materials you don't want and just back up.
this method worked for me ever since "The Forgotten" DVD came out. Other discs that i had to use this method was "Madagascar", "Resident Evil Apocalypse", and "Sky High".
I did this works great thanks
Just a side note when in shrink go to extars change to still images you will get 88% on the movie compress still have menus minus the crap
This is from the Madagascar post"Man who walk through airport turnstile backwards
going to Bangkok."
I want to back up my STEALTH dvd movie with DVD shrink like I always do but this time it failed.
It says invalid dvd structure.
I've tried Anydvd and Rejig but still no luck. Can anyone help with that matter? or point to some guide?
Norbert
DVDFAB DECRYPTER has been updated a few days ago. Try it. Do you have dvd2one? Try that after you rip it.
Life is like a pothole, you just have to learn to get around it.
I have tried fvffab and it worked then I did re-author with dvd shrink to remove unwanted stuff and it was OK.
However when i burned this onto dvd-r it won't play in my sony dvd player but it's playing in my computer.
Is there anything i can do to make this playable in my dvd player?
What is the MEDIA ID of those FUJI DVD-R? Use dvdinfo pro or dvd identifier to find out the MEDIA ID.Originally Posted by nniwelt
Nevermind about the media ID....I didn't read your post correctly....
It shouldn't matter that you have a SONY DVD PLAYER....It's how you're ripping the movie......you used DVD SHRINK 3.0BETA?
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 27th Sep 2010, 00:52 -
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 15:54 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
RipIt4Me, DVD Shrink, and DVD Decrypter on Vista?
By RowMan in forum DVD RippingReplies: 1Last Post: 24th Oct 2007, 23:45
